[mapserver-dev] Precision about geotransform
Mohamed Saâd HESSANE
saad.hessane at gmail.com
Fri Apr 22 03:49:08 EDT 2011
Hy list,
@Lime : I use python mapscript :
#!/usr/bin/python
# -*- coding: iso-8859-1 -*-
import mapscript
import time, csv
if __name__ == '__main__' :
mapFile = 'mapfile/mapFile.map'
maps = mapscript.mapObj(mapFile)
csvFile = csv.writer(open('rotation.csv', 'a'), delimiter='\t')
for i in range(360) :
maps.setRotation(i)
avg = 0
for j in range(5) : # 5 test and get the average
start = time.clock()
maps.draw()
end = time.clock()
avg += end-start
avg /= 5
print i, avg
csvFile.writerow([str(i), '%.2f' % avg])
The script write a csv file that you can import in OOo Calc or MS Excel. And
then make a radar graphic.
I use a 5 GB datasource of SRP rasters, tileindexed, and having overview.
The size is 600x600, and the zoom level is 1.
@Frank : I m doing a lot of tests about rotation, zooming, resizing... to
benchemark mapserver, and set a limit to my futur application. That is why
it's important to me to know why it's take less/more time in specific
angles.
2011/4/21 Frank Warmerdam <warmerdam at pobox.com>
> On 11-04-21 10:32 AM, Mohamed Saâd HESSANE wrote:
>> Hy list,
>> I have a question. I'm doing a benchmarking test of a rotated map, and i
>> get
>> the result in the attached file.
>> My question is why it take more time to draw a map rotated at 45° than a
>> map
>> rotated at 90° or 183° ???
>> Thank you !
> Mohamed,
> It is not obvious to me why you are seeing the odd
> performance-base-on-angle
> results you are encountering. I implemented the rotation support, and the
> raster resampler used for warping rasters.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110422/964db137/attachment.html
