[mapserver-dev] Undocumented changes in PHP MapScript
Alan Boudreault
aboudreault at mapgears.com
Mon Apr 25 13:34:25 EDT 2011
The methods setXY and setXYZ are still present. What do you mean? What error
message do you get when you try to use it? Not sure what you means about the
error message of setXY method... could you point me the error message you got?
Alan
On April 24, 2011 12:06:02 am Mike Leahy wrote:
> Hello List,
> I have just given the 6.0 beta 7 a try, and overall the migration guide
> made most changes that affected my application very easy to deal with, and
> from my tests MapServer and PHP MapScript are working as expected. I'm
> looking forward to the final release.
> I'm just wondering if there are any additional changes to PHP MapScript
> library that are known, but not yet documented in the migration guide. I
> seem to have encountered at least one change that is not covered, which
> tripped me
> up briefly. As the migration guide notes:
> > Object properties can be set like all other php object. ie.
> > myObj->myProperty = 10;
> > NOTE: The set/setProperty methods are still available.
> However, it seems that the pointObj->setXY() method is no longer present.
> This was easily substituted by directly setting the x/y properties (e.g.,
> $oPoint->x = $x). I recognize this particular issue is fairly trivial, but
> since this change isn't covered in the guide. I'm wondering if there might
> be other differences. There's no mention of any methods other than 'free'
> being removed from the pointObj class. In my case, the PHP code did not
> fail gracefully when it setXY method, and I had to hunt for a bit to find
> where in the code that the error was happening. In other cases, using
> removed methods produced useful error messages...so maybe something else
> has gone wrong specifically with the setXY method.
> Best regards,
> Mike
Alan Boudreault
Mapgears
http://www.mapgears.com
