[mapserver-dev] Possible to use PostGIS as a TILEINDEX to
shapefiles?
Brent Fraser
bfraser at geoanalytic.com
Thu Apr 28 13:44:16 EDT 2011
Daniel,
I hadn't considered that; thanks for the pointer. But still no
success...
I set up my LAYER definition as:
LAYER
NAME 'Landfast'
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
TILEINDEX "PG:dbname='PN2010_0911' host='thinkcentre1'
port='5432' user='PN2010_0911' password='PN2010_0911'"
DATA "select imageid, location_landfast, wkb_geometry from images"
TILEITEM "location_landfast"
Running shp2img v6.0 beta4 results in:
msDrawMap(): Image handling error. Failed to draw layer named
'Landfast'. <br>
msOGRFileOpen(): OGR error. ExecuteSQL(select imageid,
location_landfast, wkb_geometry from images) failed.
SELECT from table images failed, no such table/featureclass. <br>
ogrinfo has no problem getting at the index:
G:\>ogrinfo -sql "select imageid, location_landfast, wkb_geometry from
images" PG:"host='thinkcentre1' dbname='PN2010_0911' user='PN2010_0911'
INFO: Open of `PG:host='thinkcentre1' dbname='PN2010_0911'
user='PN2010_0911' password='PN2010_0911''
using driver `PostgreSQL' successful.
Layer name: sql_statement
Geometry: Unknown (any)
Feature Count: 3
Extent: (-24.392027, 74.808823) - (-9.363171, 78.164185)
Layer SRS WKT:
(unknown)
Geometry Column = wkb_geometry
imageid: Integer (0.0)
location_landfast: String (250.0)
OGRFeature(sql_statement):0
imageid (Integer) = 3
location_landfast (String) =
G:\GeoData\PN2010-0911\ice_edge\p230r005_20010703.shp
POLYGON ((-20.789359999999999 77.004463200000004,-15.1615524
76.001411399999995,-18.995115299999998 74.808822599999999,-24.3920269
75.729690599999998,-20.789359999999999 77.004463200000004))
OGRFeature(sql_statement):1
imageid (Integer) = 2
POLYGON ((-19.2442856 77.004463200000004,-13.616478
76.001411399999995,-17.4500408 74.808822599999999,-22.846952399999999
75.729690599999998,-19.2442856 77.004463200000004))
OGRFeature(sql_statement):2
imageid (Integer) = 1
POLYGON ((-15.1506767 78.164184599999999,-9.3631706
77.072578399999998,-13.8204384 75.943901100000005,-19.4379616
76.942634600000005,-15.1506767 78.164184599999999))
Before I get too deep into a debug session, do you have an working
example of a LAYER definition?
Best Regards,
Brent Fraser
On 4/28/2011 9:51 AM, Daniel Morissette wrote:
> I meant use CONNECTIONTYPE OGR for both the tileindex (OGR pointing to
> your postgis tileindex table) and the shapefiles (connectiontype OGR
> to read the shapefiles). This would not go through mapshape.c but
> instead mapogr.cpp:
> http://mapserver.org/input/vector/ogr.html#tileindex-with-ogr
> On 11-04-28 10:34 AM, Brent Fraser wrote:
>> Daniel,
>> Using OGR results in tlp->connectiontype==MS_OGR and fails as well.
>> The main problem (I think) is that the code after line 1901 in
>> mapshape.c does a call to msDBFGetItemIndex in preparation for getting
>> the value stored in the "location" column. It needs to be replaced with
>> the code from mapraster.c, line 468:
>> /* get the tileitem index */
>> for(i=0; i<tlp->numitems; i++) {
>> if(strcasecmp(tlp->items[i], layer->tileitem) == 0) {
>> tileitemindex = i;
>> break;
>> and there could be a few other changes as well. I'll have to do some
>> hacking...
>> Best Regards,
>> Brent Fraser
>> On 4/27/2011 9:02 PM, Daniel Morissette wrote:
>>> Unfortunately too late for 6.0 as you had already figured out. However
>>> you could use OGR connections for your PostGIS tileindex and to read
>>> your shapefiles with the current version.
>>> Daniel
>>> On 11-04-27 08:42 PM, Brent Fraser wrote:
>>>> I've used a PostGIS layer as a TILEINDEX to raster files, but it
>>>> doesn't
>>>> seem to work for pointing to shapefiles.
>>>> And looking at mapshape.c at line 1901 it checks:
>>>> tlp = (GET_LAYER(layer->map, tSHP->tilelayerindex));
>>>> if(tlp->connectiontype != MS_SHAPEFILE) {
>>>> msSetError(MS_SDEERR, "Tileindex layer must be a shapefile.",
>>>> "msTiledSHPOpenFile()");
>>>> return(MS_FAILURE);
>>>> mapraster.c has some logic around line 410 that seems more generic.
>>>> I wonder if it would be possible to fix this for 6.0, or is it too
>>>> late
>>>> now that rc1 is out?
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
