[mapserver-dev] problems serving DTED data via WCS
Jim Hammack
hammack at GotSlack.org
Tue Aug 23 15:58:24 EDT 2011
I am trying to serve DTED data in its native format using WCS with
mapserver 6.0.0 on Slackware 13.1. If I serve the data as a 16-bit
GeoTIFF or do a WCS 2.0.0 GetCoverage with a PNG output, the images look
good. But when I serve the same data using the GDAL/DTED driver the
.dt1 file contains only 0 values for the data when using GetCoverage.
Interestingly, shp2img gives me a file with nothing but 21074 (0x5252)
for the data values. In both cases the output of gdalinfo looks okay.
So it seems like mapserver is finding the data okay, but gdal (1.8.0) is
not writing the dt1 file properly.
Am I missing something in the WCS configuration or is gdal confused?
Thanks,
Jim
# this works
OUTPUTFORMAT
NAME "GEOTIFFINT16"
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE "INT16"
EXTENSION "tif"
END
shp2img -m dted1.map -i PNG -l "elevation" -o fred.dt1 -e -90.0 30.0
-89.0 31.0 # works
http://localhost/cgi-bin/mapserv?map=/mapserver/dted1.map&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&coverageid=elevation&format=png&subset=lon_axis,http://www.opengis.net/def/crs/EPSG/0/4326(-90.0,-89.0)&subset=lat_axis,http://www.opengis.net/def/crs/EPSG/0/4326(30.0,31.0)
# this does not
OUTPUTFORMAT
NAME "DTED"
DRIVER "GDAL/DTED"
IMAGEMODE "INT16"
EXTENSION "dt1"
END
shp2img -m dted1.map -i DTED -l "elevation" -o fred.dt1 -e -90.0 30.0
-89.0 31.0 # contains 0x5252 values only
http://localhost/cgi-bin/mapserv?map=/mapserver/dted1.map&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&coverageid=elevation&format=DTED&subset=lon_axis,http://www.opengis.net/def/crs/EPSG/0/4326(-90.0,-89.0)&subset=lat_axis,http://www.opengis.net/def/crs/EPSG/0/4326(30.0,31.0)
# contains zero values only
mojo:/mapserver> gdalinfo fred.dt1
Driver: DTED/DTED Elevation Raster
Files: fred.dt1
fred.dt1.aux.xml
Size is 1201, 1201
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-90.000416666666666,31.000416666666666)
Pixel Size = (0.000833333333333,-0.000833333333333)
Metadata:
DTED_VerticalAccuracy_UHL=NA
DTED_VerticalAccuracy_ACC=NA
DTED_SecurityCode_UHL=U
DTED_SecurityCode_DSI=U
DTED_UniqueRef_UHL=
DTED_UniqueRef_DSI=000000000000000
DTED_DataEdition=01
DTED_MatchMergeVersion=A
DTED_MaintenanceDate=0000
DTED_MatchMergeDate=0000
DTED_MaintenanceDescription=0000
DTED_Producer=
DTED_VerticalDatum=MSL
DTED_HorizontalDatum=WGS84
DTED_DigitizingSystem=
DTED_CompilationDate=
DTED_HorizontalAccuracy=NA
DTED_RelHorizontalAccuracy=NA
DTED_RelVerticalAccuracy=NA
DTED_OriginLatitude=0300000N
DTED_OriginLongitude=0900000W
DTED_NimaDesignator=DTED1
AREA_OR_POINT=Point
TIFFTAG_XRESOLUTION=72.000000
TIFFTAG_YRESOLUTION=72.000000
TIFFTAG_RESOLUTIONUNIT=2
Corner Coordinates:
Upper Left ( -90.0004167, 31.0004167) ( 90d 0' 1.50"W, 31d 0' 1.50"N)
Lower Left ( -90.0004167, 29.9995833) ( 90d 0' 1.50"W, 29d59'58.50"N)
Upper Right ( -88.9995833, 31.0004167) ( 88d59'58.50"W, 31d 0' 1.50"N)
Lower Right ( -88.9995833, 29.9995833) ( 88d59'58.50"W, 29d59'58.50"N)
Center ( -89.5000000, 30.5000000) ( 89d30' 0.00"W, 30d30' 0.00"N)
Band 1 Block=1x1201 Type=Int16, ColorInterp=Undefined
NoData Value=-32767
Unit Type: m
