[mapserver-dev] layer masking rfc
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Dec 1 16:18:37 EST 2011
Sounds good then- there is a way to hide a mask. Could also use a special status (kinda like QUERYONLY) of MASK or MASKONLY if we wanted to explicitly mark a layer as a mask.
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
Sent: Thursday, December 01, 2011 1:19 PM
To: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] layer masking rfc
On 2011-12-01, at 1:19 PM, Lime, Steve D (DNR) wrote:
> I guess although you do have geometry type (or assume polygon?). If type stays "as is" how do you hide masks from OGC services?
METADATA
"ows_enable_request" "!*"
END
Note that the mask can be anything, point, lines, polygons, or even a raster image, so I don't think there is any way to get away without a valid layer type value.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
