[mapserver-dev] SLD and Postgis/Postgres
Espen.Messel at ffi.no
Fri Dec 2 03:10:51 EST 2011
Hello all.
I'm struggling with SLD and Postgis/Postgres. It looks like version
6.0.1 of Mapserver do not draw a SLD based polygon layer correctly. It
looks like Mapserver only uses the first PolygonSymbolizer in the sld
for all filters.
I have tested the "Attribute-based polygon" from Geoserver SLD cookbook.
http://docs.geoserver.org/latest/en/user/styling/sld-cookbook/polygons.h
tml
Everything works fine when the mapfile use the shapefile, but after
import to Postgis/Postgres it fails. When using an older version of
Mapserver (5.2) on the same database and SLD it all works fine.
Is this a known issue, or shall I register a ticket?
Best regards,
Espen Messel
Espen Messel
Scientist
Norwegian Defence Research Establishment
Tel: +47 63807607
