[mapserver-dev] RFC81: offset labels with leader lines
thomas bonfort
thomas.bonfort at gmail.com
Fri Dec 16 13:58:53 EST 2011
On Fri, Dec 16, 2011 at 19:43, Smith, Michael ERDC-CRREL-NH
<Michael.Smith at usace.army.mil> wrote:
> Thomas,
> Would you want to add a LEADERPOSITION argument? The default being AUTO
> but then you could specify UR or the other position arguments and get the
> leaders all following the same orientation.
Is there a compelling reason to limit these orientations, is it for
consistency? Strictly limiting the position would remove all the test
positions labelled "2" on the RFC figures, in the second and
subsequent iterations. Anyhow, adding this kind of restriction would
be possible with minimal changes in a second phase should the need
come up.
> Another option might be a
> LEADERFORCE true/false option to force LEADERS even when not absolutely
> necessary (for consistency).
do you mean that a leader line should also be drawn when there is no
need for a leader and the label is in a position other than CC, or
that all labels should directly go into the leader phase without first
trying around the original position ?
Thomas
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> On 12/16/11 11:41 AM, "thomas bonfort" <thomas.bonfort at gmail.com> wrote:
>>devs,
>>please have a look and comment on
>>http://mapserver.org/trunk/development/rfc/ms-rfc-81.html
>>best regards,
>>thomas
>>_______________________________________________
>>mapserver-dev mailing list
>>mapserver-dev at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
