[mapserver-dev] variable substitution for projection
Zach Aller
allerzach at gmail.com
Wed Dec 21 17:23:42 EST 2011
that seem's to have done the trick sort of now i am just wondering if i can
set that for a specific layer i tried
map.layer[layername].projection
but that did not seem to work. Setting the map projection will probably be
fine for our project at least for now.
On Wed, Dec 21, 2011 at 11:04 AM, Lime, Steve D (DNR) <
Steve.Lime at state.mn.us> wrote:
> Zach: You should be able to change the projection through the URL like
> so:****
> …&map.projection=EPSG:3158&…****
> No need to runtime subs…****
> Steve****
> *From:* mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *Zach Aller
> *Sent:* Tuesday, December 20, 2011 5:28 PM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [mapserver-dev] variable substitution for projection****
> ok i am working with mapserver and a nodejs project and so i am calling
> mapserver like so.
> mapserv -nh
> "/getPreviewImg.map&mode=map&mapext='+req.params.extent+'&filename='+req.params.imgname+'&projection=3158"
> the issue is that mapserver dose not support projection based run time
> substitution and so i was wondering if that is possible to add and how hard
> it would be (maybe i could to it myself etc if pointed in right direction
> because i have no experience with mapserver's src)
> map file example thats what i want to replace
> PROJECTION
> "init=epsg:%projection%"
> END
> or perhaps even this then i could build what ever
> PROJECTION
> %projection%
> END****
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111221/612acd2d/attachment.html
