[mapserver-dev] variable substitution for projection
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Dec 21 17:59:58 EST 2011
Syntax will be a little different since it's not a top-level object, try:
...& map.layer[layername]=PROJECTION+EPSG:3158+END&...
That syntax would probably work for the map.projection method too (the PROJECTION/END should be stripped off).
Steve
Sent: Wednesday, December 21, 2011 4:24 PM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] variable substitution for projection
that seem's to have done the trick sort of now i am just wondering if i can set that for a specific layer i tried
map.layer[layername].projection
but that did not seem to work. Setting the map projection will probably be fine for our project at least for now.
On Wed, Dec 21, 2011 at 11:04 AM, Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>> wrote:
Zach: You should be able to change the projection through the URL like so:
...&map.projection=EPSG:3158&...
No need to runtime subs...
Steve
From: mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org>] On Behalf Of Zach Aller
Sent: Tuesday, December 20, 2011 5:28 PM
To: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Subject: [mapserver-dev] variable substitution for projection
ok i am working with mapserver and a nodejs project and so i am calling mapserver like so.
mapserv -nh "/getPreviewImg.map&mode=map&mapext='+req.params.extent+'&filename='+req.params.imgname+'&projection=3158"
the issue is that mapserver dose not support projection based run time substitution and so i was wondering if that is possible to add and how hard it would be (maybe i could to it myself etc if pointed in right direction because i have no experience with mapserver's src)
map file example thats what i want to replace
PROJECTION
"init=epsg:%projection%"
END
or perhaps even this then i could build what ever
PROJECTION
%projection%
END
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111221/5d5f7669/attachment-0001.html
