[mapserver-dev] MS RFC 68: Support for combining features from
multiple layers (Call for discussion)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 14 10:15:51 EST 2011
Hi Tamas,
Oh ok I see. Can you add this example to the RFC so it documented? Thanks.
-jeff
On 11-02-14 11:03 AM, Tamas Szekeres wrote:
> Hi Jeff,
> 'Cluster:FeatureCount' would be added to the CLUSTER layer as an
> additional attribute. In this regard it can be used as the text data
> when labelling the features, I imagine something like:
> LAYER
> TYPE POINT
> NAME cluster
> CONNECTIONTYPE CLUSTER
> PROCESSING "SOURCELAYER=layername"
> CLASS
> EXPRESSION ([Cluster:FeatureCount] > 1)
> TEXT ([Cluster:FeatureCount])
> LABEL
> END
> END
> END
> I would prefer this option to work even with the STYLEITEM "AUTO"
> setting, where the styles for the source layer would be retrieved only
> for the individual shapes not for the clustered shapes. I hope I can
> provide a working example soon.
> Best regards,
> Tamas
> 2011/2/14 Jeff McKenna <jmckenna at gatewaygeomatics.com
> <mailto:jmckenna at gatewaygeomatics.com>>
> Hello Tamas,
> This is a very interesting proposal. I often have a hard time to
> picture these changes beforehand, but I am trying to now and I have
> a question: when it comes to clustering, I think a common need is
> also to label the number of clustered points...and since you'll know
> how many features are combined according to your proposal (I see
> 'Cluster:FeatureCount' mentioned in the RFC) I believe we must also
> expose this clustercount in the label object. How I am not sure,
> but to me this will be a common need. Or is this mentioned in the
> RFC already?
> -jeff
> On 11-02-10 6:02 PM, Tamas Szekeres wrote:
> Hi Devs,
> In reference to the feature request from WhereGroup
> <http://www.wheregroup.com/en/welcome> we did some refinement in the
> specification and I've created MS-RFC-68
> (http://trac.osgeo.org/mapserver/browser/trunk/docs/en/development/rfc/ms-rfc-68.txt)
> which contains a reasonable implementation to this option without
> requiring significant modifications in the MapServer codebase
> and the
> current processing chain. With regards to the timing, I already have
> some working code in place which could be finished by the time
> of the
> feature freeze of MapServer 6.0 we are targeting now (feb. 28).
