[mapserver-dev] MS RFC 68: Support for combining features from
multiple layers (Call for discussion)
Tamas Szekeres
szekerest at gmail.com
Wed Feb 16 11:11:43 EST 2011
Hi Steve,
Please find my comments inline below.
2011/2/16 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> Actually the clustering could be extended to multiple layers using the
> second part of your RFC. You’d just embed the clustering block/params
> in a layer that references other layers (however that would work). That’s
> kinda why I thought the RFCs should be separate.
I agree with the statements above, absolutely.
> The feature count parameter would be a challenge regardless of
> implementation. I need to think about this a bit. I was thinking that if a
> layer
> is to be clustered then:
> - msLayerGetItems() would tag on a this new item in addition to
> whatever the layer defines
> - the clustering operation would populate it
> Being able to extend a layers default item set and then populating it at
> the shape level is a need we have not only in this case. The 3D buildings
> idea thrown out on mapserver-users also would use this. We should consider
> an general approach to that topic.
> Again, let me think just a touch on this and reply back. Ideally we should
> only have to override the vtable function for msLayerNextShape(). I’m
> thinking:
> - msLayerOpen() is unchanged
> - msLayerGetItems() is smart enough to add the new item for
> feature count
> - msClusterLayer() is a new function, it uses the stock
> msLayerNextShape() function to read shapes and build clusters, the feature
> count is maintained here.
> - msLayerNextShape() is overridden to access the cluster cache
> - msLayerWhichShapes() is unchanged
I would be in favour of writing the code (in mapcluster.c) in such way which
could provide the clustering in the builtin approach (you mention) and it
could eventially be a driver (ie a builtin or a plugin) as well. This would
leave the decision up to the user whether to support the query or just to
use this for rendering purposes. In this case using a custom version of
msClusterLayerOpen (being called from msDrawLayer) would be quite
straightforward to implement. msClusterLayerOpen could do any vtable
adjustments as required for the driver.
> This would then require almost no change to existing code… You could use
> the inline feature list already present in a layerObj to store the clustered
> Shapes. Of course then you couldn’t cluster inline shapes but perhaps
> that’s not a big deal (wouldn’t think it would be).
I'm a bit reluctant to use the inline feature list for now. Since the
clustered features are in place, there's no need to populate a new list with
the features. In addition, the inline features are written in the mapfile as
well which is a fairly unwanted effect.
> For querying, hmmm… Let me think on that too…
In this case the user would use the separate layer with this new
connectiontype, where the clustered features would be available for the
query as well.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110216/279c448e/attachment-0001.html
