[mapserver-dev] MS RFC 68: Support for combining features from
multiple layers (Call for discussion)
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Feb 16 10:55:12 EST 2011
Actually I’m warming to the idea first presented in the RFC, basically a cluster driver. It concentrates all this processing in one spot and doesn’t further complicate things like msDrawLayer()… I don’t know a way to really address querying without going this route.
Steve
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Wednesday, February 16, 2011 6:27 AM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] MS RFC 68: Support for combining features from multiple layers (Call for discussion)
Steve,
As far as I can see, your preference is to implement the clustering within the same layer instead of referring to another layer, right?
(With regards to the parameters there's not too much difference in the concept with having processing options vs. built in parameters.)
With this end in view, I foresee 2 main problems which is not quite trivial in this approach.
1. How the FeatureCount parameter will be used for labelling the clustered features?
2. How can we make the clustered features selectable (queryable). / this is not a strong requirement of mine at this phase /
With regards to the implementation how about invoking a custom LayerOpen in msDrawVectorLayer, something like?:
if (needtocluster) // based of the existence of the cluster parameters
msClusterLayerOpen(layer); // this would override the vtable methods: LayerGetItems/LayerInitIteminfo/LayerWhichShapes/LayerNextShape
else
mslayerOpen(layer);
// the remaining code would be the same in effect (not modified)
msLayerWhichItems(layer); // LayerGetItems/LayerInitIteminfo would be aware of the FeatureCount parameter.
msLayerWhichShapes(layer, rect) // build up the cluster database here, call WhichItems/LayerWhichShapes/LayerNextShape for the underlying connection type
while(msLayerNextShape(layer, shape) == MS_SUCCESS) // shapes would be served from the cluster database
msDrawShape(shape); // normal drawing process
msLayerClose(layer); // restore the original vtable
Best regards,
Tamas
2011/2/15 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Sorry, I mean clustering shouldn’t be a new connection type, rather a block or optionally a set of processing directives, so:
LAYER
NAME mypoints
TYPE POINT
# whatever data and/or connection params
CLUSTERS # or processing directives
END
# class and style info
END
The decision to use a block or processing directives would depend on the complexity of configuration. If clustering could
potentially support lots of tuning then I’d favor an explicit configuration block.
I think both pieces of functionality outlined are potentially useful. I’d recommend limiting the scope of the RFC to clustering
to start with… There is some limited (and non-configurable) support for not labeling over point features already present in
the label cache code so I see more limited utility in the layer combination portion of the RFC.
Steve
From: mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org>] On Behalf Of Tamas Szekeres
Sent: Tuesday, February 15, 2011 11:38 AM
Cc: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
I see value in both but kinda think they should be handled with separate RFCs since you don’t need one for the
other and neither problem is trivial.
Steve,
I can accept to create separate RFCs (however I require them both in my project to succeed ;-)
At least on the clustering side I don’t think that should be handled as a connection type. Rather I’d favor a new
CLUSTER block where you’d set the various tolerance and scale values. That way you could add clustering to a
point layer without much effort. I think it needs to be that simple.
I don't see the difference with regards to the data processing. For the setting of the parameters via a CLUSTER block instead of some PROCESSING option doesn't seem to differ significantly. But if you want to include this algorithm somewhere into the MapServer core that would be another case.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110216/ff6f4940/attachment.html
