[mapserver-dev] FAILS in msautotest
thomas bonfort
thomas.bonfort at gmail.com
Tue Jan 4 08:28:04 EST 2011
OUTPUTFORMAT
DRIVER "GD/PNG"
IMAGEMODE PC256
END
note that the GD driver only supports PC256, mapserver will switch to
AGG if you request RGB or RGBA. also note that all the other drivers
do not support PC256 (i.e. only RGB and RGBA)
thomas
On Tue, Jan 4, 2011 at 14:19, Peter Hopfgartner
<peter.hopfgartner at r3-gis.com> wrote:
> What should the former
> OUTPUTFORMAT
> IMAGEMODE PC256
> END
> look like, now?
> Regards
> Peter
> R3 GIS Srl - GmbH
> http://www.r3-gis.com
> --------"Lime, Steve D (DNR)" <Steve.Lime at state.mn.us> wrote--------
> Subject: RE: [mapserver-dev] FAILS in msautotest
> Date: 03.01.2011 22:07
>>The rendering plugin merge broke quite a few tests so this is expected I
>>guess. There's a ticket (http://trac.osgeo.org/mapserver/ticket/3644)
>>already created to make sure these get fixed. I believe most are due to
>>changes in the default image output types (e.g. AGGPNG24 is just PNG24 and
>>AGGJPEG is just JPEG). Actually it would be nice to get the trivial issues
>>fixed ASAP so more significant regressions can be surfaced.
>>Steve
>>-----Original Message-----
>>From: mapserver-dev-bounces at lists.osgeo.org
>>[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Peter
>>Hopfgartner
>>Sent: Monday, January 03, 2011 2:55 PM
>>To: mapserver-dev at lists.osgeo.org
>>Subject: [mapserver-dev] FAILS in msautotest
>>When I run run_test.py in msautotest, e.g. from today's svn checkout, a
>>good part of the tests fail. Is this something to be worried about or is
>>it expected?
>>Regards,
>>Peter
>>R3 GIS Srl - GmbH
>>_______________________________________________
>>mapserver-dev mailing list
>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
