[mapserver-dev] FAILS in msautotest
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Tue Jan 4 09:07:45 EST 2011
In that case the test "gdal_png_tr_256.map" might be dropped, since this feature is not supported anymore?
Regards,
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------thomas bonfort <thomas.bonfort at gmail.com> wrote--------
Subject: Re: RE: [mapserver-dev] FAILS in msautotest
Date: 04.01.2011 14:28
>OUTPUTFORMAT
>  DRIVER "GD/PNG"
>  IMAGEMODE PC256
>END
>note that the GD driver only supports PC256, mapserver will switch to
>AGG if you request RGB or RGBA. also note that all the other drivers
>do not support PC256 (i.e. only RGB and RGBA)
>thomas
>On Tue, Jan 4, 2011 at 14:19, Peter Hopfgartner
><peter.hopfgartner at r3-gis.com> wrote:
>> What should the former
>> OUTPUTFORMAT
>>  IMAGEMODE PC256
>> END
>> look like, now?
>> Regards
>> Peter
>> R3 GIS Srl - GmbH
>> --------"Lime, Steve D (DNR)" <Steve.Lime at state.mn.us> wrote--------
>> Subject: RE: [mapserver-dev] FAILS in msautotest
>> Date: 03.01.2011 22:07
>>>The rendering plugin merge broke quite a few tests so this is expected
>I
>>>guess. There's a ticket (http://trac.osgeo.org/mapserver/ticket/3644)
>>>already created to make sure these get fixed. I believe most are due to
>>>changes in the default image output types (e.g. AGGPNG24 is just PNG24
>and
>>>AGGJPEG is just JPEG). Actually it would be nice to get the trivial
>issues
>>>fixed ASAP so more significant regressions can be surfaced.
>>>Steve
>>>-----Original Message-----
>>>From: mapserver-dev-bounces at lists.osgeo.org
>>>[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Peter
>>>Hopfgartner
>>>Sent: Monday, January 03, 2011 2:55 PM
>>>To: mapserver-dev at lists.osgeo.org
>>>Subject: [mapserver-dev] FAILS in msautotest
>>>When I run run_test.py in msautotest, e.g. from today's svn checkout, a
>>>good part of the tests fail. Is this something to be worried about or
>is
>>>it expected?
>>>Regards,
>>>Peter
>>>R3 GIS Srl - GmbH
>>>_______________________________________________
>>>mapserver-dev mailing list
>>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
