[mapserver-dev] FAILS in msautotest
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Jan  4 09:28:35 EST 2011
On 11-01-04 09:07 AM, Peter Hopfgartner wrote:
> In that case the test "gdal_png_tr_256.map" might be dropped, since this feature is not supported anymore?
Peter / Thomas,
I'll review msautotest/gdal with an eye to trimming some of the now
unnecessary tests.
Best regards,
> --------thomas bonfort<thomas.bonfort at gmail.com>  wrote--------
> Subject: Re: RE: [mapserver-dev] FAILS in msautotest
> Date: 04.01.2011 14:28
>> OUTPUTFORMAT
>>   DRIVER "GD/PNG"
>>   IMAGEMODE PC256
>> END
>> note that the GD driver only supports PC256, mapserver will switch to
>> AGG if you request RGB or RGBA. also note that all the other drivers
>> do not support PC256 (i.e. only RGB and RGBA)
