[mapserver-dev] Call for vote on RFC 65...
Daniel Morissette
dmorissette at mapgears.com
Wed Jan 5 16:21:23 EST 2011
Hi Steve, (and all)
I see that you started working on the addition of a resultindex member
variable instead of reusing tileindex for two purposes.
This would address the OGR issues that I raised in my previous messages,
and I see no other blocker from my point of view. I guess the next step
would be to update the RFC to reflect this change and redo the vote.
Once the RFC is approved, I and Alan should be able to help you with the
implementation in the OGR, Oracle and PostGIS drivers (unless there are
other takers).
Daniel
On 10-12-17 03:06 PM, Lime, Steve D (DNR) wrote:
> Hopefully you guys can ponder it. When I looked at OGR the implementation of getShape and resultGetShape where identical.
> Also note that since I propose passing a resultCacheMemberObj around instead of individual id's we could support 3 ids: shape, tile and resultset.
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
> Sent: Friday, December 17, 2010 1:53 PM
> To: Lime, Steve D (DNR)
> Cc: 'MapServer Dev Mailing List'
> Subject: Re: [mapserver-dev] Call for vote on RFC 65...
>> Hi all: I’d like to call for a vote on RFC 65 - Single-pass Query
>> Changes for 6.0.
>> http://mapserver.org/development/rfc/ms-rfc-65.html
> I wonder if Frank read this RFC or if he missed the thread a couple of
> weeks ago like I did. (Sorry, I've got a big email backlog and the
> initial RFC 65 thread was still in it)
> I'm not sure that this is compatible with OGR's current implementation
> to support 5.6's ResultGetShape(). OGR does support both resultsets and
> tileindex, so reusing the tile id may not work in OGR's case (unless we
> go with something like negative tile id that means resultset, and
> positive tileid that means real tileindex id?)
Daniel Morissette
http://www.mapgears.com/
