[mapserver-dev] FAILS in msautotest
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Jan 6 13:06:30 EST 2011
I've put in fixes for 3 tests. They will be skipped, when CAIRO is not configured.
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Frank Warmerdam <warmerdam at pobox.com> wrote--------
Subject: Re: [mapserver-dev] FAILS in msautotest
Date: 04.01.2011 15:28
>On 11-01-04 09:07 AM, Peter Hopfgartner wrote:
>> In that case the test "gdal_png_tr_256.map" might be dropped, since
>this feature is not supported anymore?
>Peter / Thomas,
>I'll review msautotest/gdal with an eye to trimming some of the now
>unnecessary tests.
>Best regards,
>> --------thomas bonfort<thomas.bonfort at gmail.com>  wrote--------
>> Subject: Re: RE: [mapserver-dev] FAILS in msautotest
>> Date: 04.01.2011 14:28
>>> OUTPUTFORMAT
>>>   DRIVER "GD/PNG"
>>>   IMAGEMODE PC256
>>> END
>>> note that the GD driver only supports PC256, mapserver will switch to
>>> AGG if you request RGB or RGBA. also note that all the other drivers
>>> do not support PC256 (i.e. only RGB and RGBA)
>I set the clouds in motion - turn up   | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>mapserver-dev mailing list
>mapserver-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110106/20c4f4d6/test-without-cairo.bin
