[mapserver-dev] FAILS in msautotest
thomas bonfort thomas.bonfort at gmail.com
Thu Jan 6 16:04:49 EST 2011
Peter,
the tests in the renderer directory are a bit different in the sense
that they are run to be able to compare the output of the different
renderers on a single test case. the run-test.py there is a bit
modified as it loops through the 'png', 'png24' and 'cairopng'
outputformats which it passes as a -i switch to shp2img.
as msautotest is right now, there's no way/use of not running those
tests if cairo isn't enabled. the renderer directory is more of a dev
test-case for me to check all the renderers are consistent with one
another rather than something that indicates a serious failure (you'll
see that there aren't any "expected" results committed there either.
so, to conclude, these fixes dont' really need to be applied, as there
is no use in running the renderers/ tests if cairo isn't configured.
best regards,
thomas
On Thu, Jan 6, 2011 at 19:06, Peter Hopfgartner
<peter.hopfgartner at r3-gis.com> wrote:
> I've put in fixes for 3 tests. They will be skipped, when CAIRO is not configured.
> Peter
> R3 GIS Srl - GmbH
> http://www.r3-gis.com
> --------Frank Warmerdam <warmerdam at pobox.com> wrote--------
> Subject: Re: [mapserver-dev] FAILS in msautotest
> Date: 04.01.2011 15:28
>>On 11-01-04 09:07 AM, Peter Hopfgartner wrote:
>>> In that case the test "gdal_png_tr_256.map" might be dropped, since
>>this feature is not supported anymore?
>>Peter / Thomas,
>>I'll review msautotest/gdal with an eye to trimming some of the now
>>unnecessary tests.
>>Best regards,
>>> --------thomas bonfort<thomas.bonfort at gmail.com>  wrote--------
>>> Subject: Re: RE: [mapserver-dev] FAILS in msautotest
>>> Date: 04.01.2011 14:28
>>>> OUTPUTFORMAT
>>>>   DRIVER "GD/PNG"
>>>>   IMAGEMODE PC256
>>>> END
>>>> note that the GD driver only supports PC256, mapserver will switch to
>>>> AGG if you request RGB or RGBA. also note that all the other drivers
>>>> do not support PC256 (i.e. only RGB and RGBA)
>>I set the clouds in motion - turn up   | Frank Warmerdam,
>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>and watch the world go round - Rush    | Geospatial Programmer for Rent
>>_______________________________________________
>>mapserver-dev mailing list
>>mapserver-dev at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
