[mapserver-dev] Quote escaping in mapfile strings
Daniel Morissette
dmorissette at mapgears.com
Tue Jan 11 23:10:49 EST 2011
An issue that keeps coming back every once in a while is the lack of a
mechanism to escape quotes (') and double quotes (") inside strings in
mapfiles.
6.0 would be a good time to address this in case the fix implies new
mapfile rules or limitations.
The first step is to decide on the syntax to escape quotes. Can anyone
think of a magic solution to this problem that will make everybody happy?
Here are a few thoughts:
1- An obvious approach could be to use C escaping: \' , \" and \\ ...
but unfortunately that would force the use of double \\ in all windows
filename paths. I realize that one could use "/" on Windows instead but
using this approach could cause unnecessary confusion with beginners and
become a FAQ that comes up more often than the use dummy TEMPLATEs to
enable queries in MapScript.
2- Another approach could be to use two double quotes ("") to escape a
double quote, and two single quotes ('') to escape a single quote
e.g.
"This string contains ""Double Quotes"""
'This string contains ''Single Quotes'''
"You don't need to escape single quotes in this string since it uses
double quotes ("") as delimiter"
'And the same way "Double Quotes" don't need escaping here'
"Two ''single quotes'' in this string are not considered an escape
sequence and remain two individual chars'
/me thinks #2 could work with a minimum of disruption to existing
mapfiles, unless I missed something. We'd need Steve's opinion on how
this can be implemented in the parser.
Anyone have better suggestions?
Daniel
Daniel Morissette
http://www.mapgears.com/
