[mapserver-dev] 6.0 release scheduling
Martin Kofahl
m.kofahl at gmx.net
Thu Jan 13 06:22:17 EST 2011
I just got through the technical guidance to implement inspire view
services.
a) The most simple part to implement are additional metadata in the
capabilities, I think. There are a lot of new fields, but as far I know
they can be implemented using the mapfile metadata section.
b) Regarding multi-language support I remember a post on this list
proposing wms_abstract_eng etc. metadata keywords. It is only required
for title, abstract, description. One language has to be set as default.
Thus one could set the default language in the web metadata section and
alter the metadata lookup function to use the default or given
(&language=..) language for title, abstract, description. If the
requested language is not provided the default one has to be used.
c) Layer Grouping. I prefer the idea to let a layer using
wms_layer_group being a normal layer with all it's features. See
http://trac.osgeo.org/mapserver/ticket/1632. Requesting such a layer in
GetMap could e.g. require a separate legend which can be easily
configures here. Also one could improve the map quality in stead of only
rendering all sublayers (some objects may overlap etc.). But I didn't
took a looke how wms_layer_groups works, yet.
In case one does not want to configure a dataset multiple times on
different levels one could easily usw the wms_requires ([groupname] or
[sublayername]) and hide this layer from capabilities (I do use #1952
for this).
Kind regards,
Martin
On 13.01.2011 04:20, Yewondwossen Assefa wrote:
> Hi Daniel,
>> There was also a list of INSPIRE compliance issues that was sent to
>> this list a few months ago. I didn't have a chance to review it
>> myself but I believe Assefa did. Assefa: could we realistically
>> address some/most of these for 6.0?
> As a reference, discussions regarding this are in
> http://trac.osgeo.org/mapserver/ticket/3608
> From my understanding, there are at least 2 major parts that we need
> to address to be able to be INSPIRE compliant:
> - the layer grouping part
> - the multi-language support
> The discussions happened mainly around the layer grouping. There is a
> possible solution proposed in the trac bug although It still needs
> some back and forth to clarify some parts and determine that It is a
> workable solution.
> There was no discussions that happened around on the language support.
> This need to researched a bit to identify the solutions. Off hand I do
> not know all the implications on this (some input was given here by
> Bart at one point [1])
> I believe the grouping part can be addressed for 6.0. I am unsure yet
> about the multi-language part.
> [1]:
> http://osgeo-org.1803224.n2.nabble.com/metadata-language-parameter-inspire-td5167358.html
> regards,
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110113/936be3cb/smime-0001.bin
