[mapserver-dev] RFC 66 - Better handling of temporary files
Daniel Morissette
dmorissette at mapgears.com
Fri Jan 14 16:25:07 EST 2011
On 11-01-14 04:23 PM, Frank Warmerdam wrote:
> I like the idea of being able to control where my MapServer temp
> files are created - either so I can keep them separate from system
> temporary files, or so I can control what drive they are on (ie.
> ram drive, extra physical drive). But it might be nice if the
> *fallback* when it isn't set is to do the normal system behavior.
Agreed that the fallback should be the default system temp dir and
MapServer should not require any explicit TEMPPATH configuration to work
by default.
Daniel Morissette
http://www.mapgears.com/
