[mapserver-dev] MapServer 5.6.6 release
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Fri Jan 14 17:21:56 EST 2011
+1 on 5.6.6... Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen Assefa
Sent: Friday, January 14, 2011 4:10 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] MapServer 5.6.6 release
Thanks. I have quickly built it on windows and It works as expected.
+1 based on the RC-2
On 14/01/2011 3:36 PM, Daniel Morissette wrote:
> Hi Assefa, and all,
> I have packaged a RC2 with your the latest fixes:
> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc2.tar.gz
> Daniel
> On 11-01-14 01:44 PM, Yewondwossen Assefa wrote:
>> Daniel,
>> Is it possible to prepare an RC-2. There were 2 fixes this morning just
>> after RC-1 has been prepared.
>> Thanks
>> On 14/01/2011 10:07 AM, Daniel Morissette wrote:
>>> Hi PSC,
>>> I see that the OSGeo Live DVD team is planning its feature freeze for
>>> Jan 31st, and to make sure the version of MapServer that is included
>>> will contain the latest fixes, I propose that we release MapServer
>>> 5.6.6 with what is currently in SVN branch-5-6 which includes some
>>> important fixes, a copy of the list is included below.
>>> I have packaged a 5.6.6-rc1 for testing:
>>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
>>> Please test it and report your results here. I'd like to post the
>>> 5.6.6 release on Monday if we have enough positive feedback results by
>>> then, otherwise that would have to wait until Jan 27-28 since I'll be
>>> away from Jan 18 to 26.
>>> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
>>> Daniel
>>> Change log for MapServer 5.6.6:
>>> - Fixed missing time in msDrawMap logging (#3651)
>>> - Fixed Internal error with Oracle Spatial multi point geometries
>>> (#3627)
>>> - Fixed double free in shp2img.c (#3497)
>>> - Fixed free(): invalid next size in mapfile.c (#3604)
>>> - Fix for the memory corruption when mapping the string data type in
>>> the Java bindings (3491)
>>> - Correct wms 1.3.0 latlong bbox error (#2578)
>>> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
>>> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
>>> - Fixed crash when drawing a map using UNIQUE fid in the layer data
>>> (#3271)
>>> - Fixed Oracle Spatial Data gets corrupt (#3541)
>>> - Fixed issue with multiple styles and binding (#3538)
>>> - Fixed multiple include tags not supported in xml mapfiles (#3530)
>>> - Ensure the class is not marked BeforeFieldInit causing memory
>>> corruption with C#/CLR4 (#3438)
>>> - Fixed MSSQL2008 driver returning invalid extent (#3498)
>>> - Fix computation of shape bounds when the first line contains no
>>> points
>>> (#3119)(fixes #3383)
>>> - Fixed error message tiles on zero-sized map cause memory allocation
>>> errors in maperror.c. (#3524)
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
