[mapserver-dev] MapServer 5.6.6 release
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 14 17:35:23 EST 2011
+1 on 5.6.6
-Steve W
On 1/14/2011 5:21 PM, Lime, Steve D (DNR) wrote:
> +1 on 5.6.6... Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen Assefa
> Sent: Friday, January 14, 2011 4:10 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] MapServer 5.6.6 release
> Thanks. I have quickly built it on windows and It works as expected.
> +1 based on the RC-2
> On 14/01/2011 3:36 PM, Daniel Morissette wrote:
>> Hi Assefa, and all,
>> I have packaged a RC2 with your the latest fixes:
>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc2.tar.gz
>> Daniel
>> On 11-01-14 01:44 PM, Yewondwossen Assefa wrote:
>>> Daniel,
>>> Is it possible to prepare an RC-2. There were 2 fixes this morning just
>>> after RC-1 has been prepared.
>>> Thanks
>>> On 14/01/2011 10:07 AM, Daniel Morissette wrote:
>>>> Hi PSC,
>>>> I see that the OSGeo Live DVD team is planning its feature freeze for
>>>> Jan 31st, and to make sure the version of MapServer that is included
>>>> will contain the latest fixes, I propose that we release MapServer
>>>> 5.6.6 with what is currently in SVN branch-5-6 which includes some
>>>> important fixes, a copy of the list is included below.
>>>> I have packaged a 5.6.6-rc1 for testing:
>>>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
>>>> Please test it and report your results here. I'd like to post the
>>>> 5.6.6 release on Monday if we have enough positive feedback results by
>>>> then, otherwise that would have to wait until Jan 27-28 since I'll be
>>>> away from Jan 18 to 26.
>>>> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
>>>> Daniel
>>>> Change log for MapServer 5.6.6:
>>>> - Fixed missing time in msDrawMap logging (#3651)
>>>> - Fixed Internal error with Oracle Spatial multi point geometries
>>>> (#3627)
>>>> - Fixed double free in shp2img.c (#3497)
>>>> - Fixed free(): invalid next size in mapfile.c (#3604)
>>>> - Fix for the memory corruption when mapping the string data type in
>>>> the Java bindings (3491)
>>>> - Correct wms 1.3.0 latlong bbox error (#2578)
>>>> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
>>>> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
>>>> - Fixed crash when drawing a map using UNIQUE fid in the layer data
>>>> (#3271)
>>>> - Fixed Oracle Spatial Data gets corrupt (#3541)
>>>> - Fixed issue with multiple styles and binding (#3538)
>>>> - Fixed multiple include tags not supported in xml mapfiles (#3530)
>>>> - Ensure the class is not marked BeforeFieldInit causing memory
>>>> corruption with C#/CLR4 (#3438)
>>>> - Fixed MSSQL2008 driver returning invalid extent (#3498)
>>>> - Fix computation of shape bounds when the first line contains no
>>>> points
>>>> (#3119)(fixes #3383)
>>>> - Fixed error message tiles on zero-sized map cause memory allocation
>>>> errors in maperror.c. (#3524)
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
