[mapserver-dev] MapServer 5.6.6 release
Tamas Szekeres
szekerest at gmail.com
Fri Jan 14 17:58:10 EST 2011
+1
Tamas
2011/1/14 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> +1 on 5.6.6... Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen Assefa
> Sent: Friday, January 14, 2011 4:10 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] MapServer 5.6.6 release
> Thanks. I have quickly built it on windows and It works as expected.
> +1 based on the RC-2
> On 14/01/2011 3:36 PM, Daniel Morissette wrote:
> > Hi Assefa, and all,
> > I have packaged a RC2 with your the latest fixes:
> > http://download.osgeo.org/mapserver/mapserver-5.6.6-rc2.tar.gz
> > Daniel
> > On 11-01-14 01:44 PM, Yewondwossen Assefa wrote:
> >> Daniel,
> >> Is it possible to prepare an RC-2. There were 2 fixes this morning just
> >> after RC-1 has been prepared.
> >> Thanks
> >> On 14/01/2011 10:07 AM, Daniel Morissette wrote:
> >>> Hi PSC,
> >>> I see that the OSGeo Live DVD team is planning its feature freeze for
> >>> Jan 31st, and to make sure the version of MapServer that is included
> >>> will contain the latest fixes, I propose that we release MapServer
> >>> 5.6.6 with what is currently in SVN branch-5-6 which includes some
> >>> important fixes, a copy of the list is included below.
> >>> I have packaged a 5.6.6-rc1 for testing:
> >>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
> >>> Please test it and report your results here. I'd like to post the
> >>> 5.6.6 release on Monday if we have enough positive feedback results by
> >>> then, otherwise that would have to wait until Jan 27-28 since I'll be
> >>> away from Jan 18 to 26.
> >>> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
> >>> Daniel
> >>> Change log for MapServer 5.6.6:
> >>> - Fixed missing time in msDrawMap logging (#3651)
> >>> - Fixed Internal error with Oracle Spatial multi point geometries
> >>> (#3627)
> >>> - Fixed double free in shp2img.c (#3497)
> >>> - Fixed free(): invalid next size in mapfile.c (#3604)
> >>> - Fix for the memory corruption when mapping the string data type in
> >>> the Java bindings (3491)
> >>> - Correct wms 1.3.0 latlong bbox error (#2578)
> >>> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
> >>> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
> >>> - Fixed crash when drawing a map using UNIQUE fid in the layer data
> >>> (#3271)
> >>> - Fixed Oracle Spatial Data gets corrupt (#3541)
> >>> - Fixed issue with multiple styles and binding (#3538)
> >>> - Fixed multiple include tags not supported in xml mapfiles (#3530)
> >>> - Ensure the class is not marked BeforeFieldInit causing memory
> >>> corruption with C#/CLR4 (#3438)
> >>> - Fixed MSSQL2008 driver returning invalid extent (#3498)
> >>> - Fix computation of shape bounds when the first line contains no
> >>> points
> >>> (#3119)(fixes #3383)
> >>> - Fixed error message tiles on zero-sized map cause memory allocation
> >>> errors in maperror.c. (#3524)
> >>> _______________________________________________
> >>> mapserver-dev mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110114/bc872cf9/attachment-0001.html
