[mapserver-dev] MapServer 5.6.6 release
thomas bonfort
thomas.bonfort at gmail.com
Fri Jan 14 18:01:04 EST 2011
+1
thomas
On Fri, Jan 14, 2011 at 23:58, Tamas Szekeres <szekerest at gmail.com> wrote:
> +1
> Tamas
> 2011/1/14 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
>> +1 on 5.6.6... Steve
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yewondwossen
>> Assefa
>> Sent: Friday, January 14, 2011 4:10 PM
>> To: mapserver-dev at lists.osgeo.org
>> Subject: Re: [mapserver-dev] MapServer 5.6.6 release
>> Thanks. I have quickly built it on windows and It works as expected.
>> +1 based on the RC-2
>> On 14/01/2011 3:36 PM, Daniel Morissette wrote:
>> > Hi Assefa, and all,
>> > I have packaged a RC2 with your the latest fixes:
>> > http://download.osgeo.org/mapserver/mapserver-5.6.6-rc2.tar.gz
>> > Daniel
>> > On 11-01-14 01:44 PM, Yewondwossen Assefa wrote:
>> >> Daniel,
>> >> Is it possible to prepare an RC-2. There were 2 fixes this morning just
>> >> after RC-1 has been prepared.
>> >> Thanks
>> >> On 14/01/2011 10:07 AM, Daniel Morissette wrote:
>> >>> Hi PSC,
>> >>> I see that the OSGeo Live DVD team is planning its feature freeze for
>> >>> Jan 31st, and to make sure the version of MapServer that is included
>> >>> will contain the latest fixes, I propose that we release MapServer
>> >>> 5.6.6 with what is currently in SVN branch-5-6 which includes some
>> >>> important fixes, a copy of the list is included below.
>> >>> I have packaged a 5.6.6-rc1 for testing:
>> >>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
>> >>> Please test it and report your results here. I'd like to post the
>> >>> 5.6.6 release on Monday if we have enough positive feedback results by
>> >>> then, otherwise that would have to wait until Jan 27-28 since I'll be
>> >>> away from Jan 18 to 26.
>> >>> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
>> >>> Daniel
>> >>> Change log for MapServer 5.6.6:
>> >>> - Fixed missing time in msDrawMap logging (#3651)
>> >>> - Fixed Internal error with Oracle Spatial multi point geometries
>> >>> (#3627)
>> >>> - Fixed double free in shp2img.c (#3497)
>> >>> - Fixed free(): invalid next size in mapfile.c (#3604)
>> >>> - Fix for the memory corruption when mapping the string data type in
>> >>> the Java bindings (3491)
>> >>> - Correct wms 1.3.0 latlong bbox error (#2578)
>> >>> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
>> >>> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
>> >>> - Fixed crash when drawing a map using UNIQUE fid in the layer data
>> >>> (#3271)
>> >>> - Fixed Oracle Spatial Data gets corrupt (#3541)
>> >>> - Fixed issue with multiple styles and binding (#3538)
>> >>> - Fixed multiple include tags not supported in xml mapfiles (#3530)
>> >>> - Ensure the class is not marked BeforeFieldInit causing memory
>> >>> corruption with C#/CLR4 (#3438)
>> >>> - Fixed MSSQL2008 driver returning invalid extent (#3498)
>> >>> - Fix computation of shape bounds when the first line contains no
>> >>> points
>> >>> (#3119)(fixes #3383)
>> >>> - Fixed error message tiles on zero-sized map cause memory allocation
>> >>> errors in maperror.c. (#3524)
>> >>> _______________________________________________
>> >>> mapserver-dev mailing list
>> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Assefa Yewondwossen
>> Software Analyst
>> Email: yassefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
