[mapserver-dev] MapServer 5.6.6 release
Perry Nacionales
pnaciona at gmail.com
Fri Jan 14 17:38:05 EST 2011
+1 on 5.6.6
-Perry
On Jan 14, 2011 9:10 AM, "Daniel Morissette" <dmorissette at mapgears.com>
wrote:
> Hi PSC,
> I see that the OSGeo Live DVD team is planning its feature freeze for
> Jan 31st, and to make sure the version of MapServer that is included
> will contain the latest fixes, I propose that we release MapServer 5.6.6
> with what is currently in SVN branch-5-6 which includes some important
> fixes, a copy of the list is included below.
> I have packaged a 5.6.6-rc1 for testing:
> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
> Please test it and report your results here. I'd like to post the 5.6.6
> release on Monday if we have enough positive feedback results by then,
> otherwise that would have to wait until Jan 27-28 since I'll be away
> from Jan 18 to 26.
> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
> Daniel
> Change log for MapServer 5.6.6:
> - Fixed missing time in msDrawMap logging (#3651)
> - Fixed Internal error with Oracle Spatial multi point geometries (#3627)
> - Fixed double free in shp2img.c (#3497)
> - Fixed free(): invalid next size in mapfile.c (#3604)
> - Fix for the memory corruption when mapping the string data type in the
> Java bindings (3491)
> - Correct wms 1.3.0 latlong bbox error (#2578)
> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
> - Fixed crash when drawing a map using UNIQUE fid in the layer data
(#3271)
> - Fixed Oracle Spatial Data gets corrupt (#3541)
> - Fixed issue with multiple styles and binding (#3538)
> - Fixed multiple include tags not supported in xml mapfiles (#3530)
> - Ensure the class is not marked BeforeFieldInit causing memory
> corruption with C#/CLR4 (#3438)
> - Fixed MSSQL2008 driver returning invalid extent (#3498)
> - Fix computation of shape bounds when the first line contains no points
> (#3119)(fixes #3383)
> - Fixed error message tiles on zero-sized map cause memory allocation
> errors in maperror.c. (#3524)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110114/e18b081b/attachment.html
