[mapserver-dev] WMS GFI with GROUPed layers
Stephan Holl
stephan.holl at intevation.de
Fri Jan 28 05:12:26 EST 2011
Hello Assefa,
Stephan Holl <stephan.holl at intevation.de>, [20110126 - 07:50:55]
> Assefa,
> On Tuesday 25 January 2011 18:46:01 Yewondwossen Assefa wrote:
> > Hi Stephan,
> > From what I can in the code, this should already be the case. Is
> > it not working? I checked 5.6.x and trunk.
> currently not, no. But I have to double check if every layer is
> queryable by its own first. I will come back to you later.
Well, there were some layers which were not queryable. So yes, you are
right, everthing works as expected. Thanks for your clarification.
However, is there a way to display some layers inside a GFI-enabled
group to manually exclude them from GFI atm?
It would be handy to have an METADATA-entry to disable GFI inside a
Layer-group for individual layers.
Best
Stephan
> > On 25/01/2011 11:57 AM, Stephan Holl wrote:
> > > Hello MS-devs,
> > > while playing arround with GFI and GROUPed layers I would like to
> > > know if there are plans to make GFI for alls members of a GROUP
> > > work. Of course this should only work for GFI-enabled layers.
> > > GetLegendGraphics also does this and offers a legend-image with
> > > all layers of the GROUP.
> > > Does anybody know more?
> > > TIA.
> > > Best
> > > Stephan
> > > _______________________________________________
> > > mapserver-dev mailing list
> > > mapserver-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110128/b80771c4/signature.bin
