[mapserver-dev] Performance problem with oracle spatial in
mapserver 6
Holger Schiebold
hschiebold at codematix.de
Wed Jun 1 09:32:44 EDT 2011
Hi Mike,
both datasources are point data in one view / table with srid and the
performance problem has nothing to do with transforming or the oracle
itself (i checked every statement). I tested it again - the only thing i
change is mapserver binary from 5.4.0 to 5.6.4 and i can see in the
logfile and in my wms client the performance difference. Both views /
tables have more then 30 columns which at the end are used in the
getFeatureInfo. But the performance problem i have already with a normal
getMap request to the mapserver binary.
regards
Holger
Am 01.06.2011 12:55, schrieb Smith, Michael ERDC-CRREL-NH:
> Holger,
> I've done some performance testing on MapServer (a number of versions,
> including 6) using Oracle Spatial (its our main data source) and haven't run
> into this issue. I'll do some checks today with some large datasets and see
> if I can replicate the issue.
> Are these 2d, 3d or 4d datasets? Points, lines or polygons? Do these layers
> have defined SRIDs? Same input/output projection?
> Mike
Holger Schiebold
____________________
codematix GmbH
Felsbachstrasse 5/7
D-07745 Jena
Tel. +49 (3641) 3038-34
www.codematix.de
