[mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
Stephan Holl stephan.holl at intevation.de
Tue Jun 28 02:32:22 EDT 2011
Hello Assefa,
thanks for catching up.
Yewondwossen Assefa <yassefa at dmsolutions.ca>, [20110627 - 13:20:25]
> On 27/06/2011 12:15 PM, Lime, Steve D (DNR) wrote:
> > Assefa will need to chime in on this one. It's not related to any
> > of the new common expressions since you're doing native filters...
> I believe this is related to
> http://trac.osgeo.org/mapserver/ticket/3481
yes, me too. Is there a fix available where this will be fixed also for
OGR and SDE-layer-types? Currently SDE-filtering is broken though.
TIA.
	Stephan
> > -----Original Message-----
> > From: mapserver-dev-bounces at lists.osgeo.org
> > [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephan
> > Holl Sent: Friday, June 24, 2011 5:24 AM To:
> > mapserver-dev at lists.osgeo.org Subject: [mapserver-dev] recent
> > Hallo devs, users,
> > while using MS and Java MapScript under Windows quite heavily atm
> > we discovered a problem regarding the FILTER-keyword between r11784
> > and 11846.
> > At r11846 the setFilter()-mapscript-method stops at the first blank
> > in the filter-statement, while the older build works well.
> > SVN-diffing through the HISTORY.txt lets me stop at #3481, where
> > Assefa added the latest comment about a failure in OGR-layers with
> > an exact same filter.
> > My layer is a SDE-connection with a large FILTER:
> > FILTER "where [foo] = 'bar' and [baz] = 1 ..."
> > With r11845 we only get a FILTER "where " written out from
> > MapScript while r11784 works well.
> > Can someone with more detailed knowledge of the code comment or
> > even approve this?
> > Best regards
> > 	Stephan
> > Stephan Holl<stephan.holl at intevation.de>  | Tel.: +49 (0)541-33 508
> > 3663 Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück -
> > HR B 18998 Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr.
> > Jan-Oliver Wagner
> > mapserver-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110628/e28223ae/signature.bin
