[mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Jun 27 13:20:25 EDT 2011
On 27/06/2011 12:15 PM, Lime, Steve D (DNR) wrote:
> Assefa will need to chime in on this one. It's not related to any of the new common expressions since you're doing native filters...
I believe this is related to http://trac.osgeo.org/mapserver/ticket/3481
Assefa
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephan Holl
> Sent: Friday, June 24, 2011 5:24 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: [mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
> Hallo devs, users,
> while using MS and Java MapScript under Windows quite heavily atm we discovered a problem regarding the FILTER-keyword between r11784 and 11846.
> At r11846 the setFilter()-mapscript-method stops at the first blank in the filter-statement, while the older build works well.
> SVN-diffing through the HISTORY.txt lets me stop at #3481, where Assefa added the latest comment about a failure in OGR-layers with an exact same filter.
> My layer is a SDE-connection with a large FILTER:
> FILTER "where [foo] = 'bar' and [baz] = 1 ..."
> With r11845 we only get a FILTER "where " written out from MapScript while r11784 works well.
> Can someone with more detailed knowledge of the code comment or even approve this?
> Best regards
> Stephan
> Stephan Holl<stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
> Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
