[mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
Lime, Steve D (DNR) steve.lime at state.mn.us
Mon Jun 27 12:15:28 EDT 2011
Assefa will need to chime in on this one. It's not related to any of the new common expressions since you're doing native filters...
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephan Holl
Sent: Friday, June 24, 2011 5:24 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
Hallo devs, users,
while using MS and Java MapScript under Windows quite heavily atm we discovered a problem regarding the FILTER-keyword between r11784 and 11846.
At r11846 the setFilter()-mapscript-method stops at the first blank in the filter-statement, while the older build works well.
SVN-diffing through the HISTORY.txt lets me stop at #3481, where Assefa added the latest comment about a failure in OGR-layers with an exact same filter.
My layer is a SDE-connection with a large FILTER:
FILTER "where [foo] = 'bar' and [baz] = 1 ..."
With r11845 we only get a FILTER "where " written out from MapScript while r11784 works well.
Can someone with more detailed knowledge of the code comment or even approve this?
Best regards
	Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
