[mapserver-dev] recent EXPRESSION/FILTER-changes in trunk
Stephan Holl
stephan.holl at intevation.de
Fri Jun 24 06:24:16 EDT 2011
Hallo devs, users,
while using MS and Java MapScript under Windows quite heavily atm we
discovered a problem regarding the FILTER-keyword between r11784 and
11846.
At r11846 the setFilter()-mapscript-method stops at the first blank in
the filter-statement, while the older build works well.
SVN-diffing through the HISTORY.txt lets me stop at #3481, where Assefa
added the latest comment about a failure in OGR-layers with an exact
same filter.
My layer is a SDE-connection with a large FILTER:
FILTER "where [foo] = 'bar' and [baz] = 1 ..."
With r11845 we only get a FILTER "where " written out from MapScript
while r11784 works well.
Can someone with more detailed knowledge of the code comment or even
approve this?
Best regards
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110624/4546f744/signature.bin
