[mapserver-dev] MapServer 6.0.0-beta1 release - Please test!
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Mar 10 12:12:18 EST 2011
Hi Daniel,
Thanks for the information.
Is there a change since 5.6.6 on those wrappers? I am asking because I
was able to update the official repositories with this version of SWIG a
couple of weeks ago...
I will make changes according to your suggestions. Thank you.
Regards,
Angelos
On 03/10/2011 06:26 PM, Daniel Morissette wrote:
> On 11-03-10 07:07 AM, Angelos Tzotsos wrote:
>> I am working on building beta1 in OpenSUSE Build Service for future
>> update of official repository.
>> I am getting the following errors:
>> https://build.opensuse.org/package/rawlog?arch=x86_64&package=mapserver&project=home%3Atzotsos%3Abranches%3AApplication%3AGeo&repository=openSUSE_11.3
> Hi Angelos,
> I see in your build logs that the Java/SWIG wrappers are generated
> using SWIG 1.3.40. I am not very familiar with the Java MapScript
> wrappers, but Tamas wrote on this list a couple of days ago:
> "I don't think that we officially went beyond 1.3.39, but for the java
> bindings 1.3.36 seems to be a better choice (on Windows)."
> The MapServer source package already contains SWIG wrappers generated
> using SWIG 1.3.36 so you could use that, or if you must regenerate
> them then I'd suggest that you try with SWIG 1.3.36.
> Daniel
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
