[mapserver-dev] MapServer 6.0.0-beta1 release - Please test! - MapScript Error
Worth Lutz wal3 at mindspring.com
Tue Mar 15 11:09:05 EDT 2011
Upon further testing while trying to get a simple test case for you, I have
determined that this problem is only on one of my two development machines.
This is the machine on which I tried to build Mapserver myself to get Cairo
support to test the PDF output of MapServer 6.0.  Apparently I loaded some
libraries or something during the build which conflict with mapscript.  The
errors I'm seeing occur with both the UbuntuGIS mapscript and the version I
built.  I'm just switching the "php_mapscript.so" files and restarting
Apache2.  Maybe this is the problem.  Since I do not really know what I'm
doing trying to build MapServer myself, I shall reinstall this system back
to where it was before and use the UbuntuGIS version of MapServer for
further testing.
When you get the chance, could you please add Cairo and PDF support to the
build on UbuntuGIS?  This is the only reason I tried to build it myself.
Thanks,
Worth
  _____
From: Alan Boudreault [mailto:aboudreault at mapgears.com]
Sent: Monday, March 14, 2011 1:17 PM
To: mapserver-dev at lists.osgeo.org
Cc: Worth Lutz; 'Daniel Morissette'
Subject: Re: [mapserver-dev] MapServer 6.0.0-beta1 release - Please test!
Please create a ticket, I'll verify if it's a ubuntugis bug or a
php/mapscript
one.
Alan
On March 14, 2011 11:36:49 am Worth Lutz wrote:
> Loaded MapServer 6.0.0 from UbuntuGIS repository.
> Using PHP mapscript:
> $ms = ms_newMapObj('mapfile');
> $metadata = $ms->getMetaData('coord_sys');
> The getMetaData statement causes a Segmentation fault.
> This works in 5.6.6.
Alan Boudreault
Mapgears
http://www.mapgears.com
  _____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1204 / Virus Database: 1498/3506 - Release Date: 03/14/11
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110315/8646ae6e/attachment.html
