[mapserver-dev] MapServer 6.0.0-beta1 release - Please test! -
MapScript Error
Alan Boudreault
aboudreault at mapgears.com
Tue Mar 15 14:39:20 EDT 2011
I'm going to update my packages right now.
Thanks,
Alan
On March 15, 2011 11:09:05 am Worth Lutz wrote:
> Upon further testing while trying to get a simple test case for you, I have
> determined that this problem is only on one of my two development machines.
> This is the machine on which I tried to build Mapserver myself to get Cairo
> support to test the PDF output of MapServer 6.0. Apparently I loaded some
> libraries or something during the build which conflict with mapscript. The
> errors I'm seeing occur with both the UbuntuGIS mapscript and the version I
> built. I'm just switching the "php_mapscript.so" files and restarting
> Apache2. Maybe this is the problem. Since I do not really know what I'm
> doing trying to build MapServer myself, I shall reinstall this system back
> to where it was before and use the UbuntuGIS version of MapServer for
> further testing.
> When you get the chance, could you please add Cairo and PDF support to the
> build on UbuntuGIS? This is the only reason I tried to build it myself.
> Thanks,
> Worth
> _____
> From: Alan Boudreault [mailto:aboudreault at mapgears.com]
> Sent: Monday, March 14, 2011 1:17 PM
> To: mapserver-dev at lists.osgeo.org
> Cc: Worth Lutz; 'Daniel Morissette'
> Subject: Re: [mapserver-dev] MapServer 6.0.0-beta1 release - Please test!
> Please create a ticket, I'll verify if it's a ubuntugis bug or a
> php/mapscript
> one.
> Alan
> On March 14, 2011 11:36:49 am Worth Lutz wrote:
> > Loaded MapServer 6.0.0 from UbuntuGIS repository.
> > Using PHP mapscript:
> > $ms = ms_newMapObj('mapfile');
> > $metadata = $ms->getMetaData('coord_sys');
> > The getMetaData statement causes a Segmentation fault.
> > This works in 5.6.6.
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> _____
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 10.0.1204 / Virus Database: 1498/3506 - Release Date: 03/14/11
Alan Boudreault
Mapgears
