[mapserver-dev] MapServer 6.0.0-beta1 release - Please test! - MapScript Error
Alan Boudreault aboudreault at mapgears.com
Wed Mar 16 10:19:12 EDT 2011
BTW, the cairo support has been added in ubuntugis packages. Though the
maverick packages should be built in a hour or so..
Alan
On March 15, 2011 02:39:20 pm Alan Boudreault wrote:
> I'm going to update my packages right now.
> Thanks,
> Alan
> On March 15, 2011 11:09:05 am Worth Lutz wrote:
> > Upon further testing while trying to get a simple test case for you, I
> > have determined that this problem is only on one of my two development
> > machines. This is the machine on which I tried to build Mapserver myself
> > to get Cairo support to test the PDF output of MapServer 6.0.
> > Apparently I loaded some libraries or something during the build which
> > conflict with mapscript.  The errors I'm seeing occur with both the
> > UbuntuGIS mapscript and the version I built.  I'm just switching the
> > "php_mapscript.so" files and restarting Apache2.  Maybe this is the
> > problem.  Since I do not really know what I'm doing trying to build
> > MapServer myself, I shall reinstall this system back to where it was
> > before and use the UbuntuGIS version of MapServer for further testing.
> > When you get the chance, could you please add Cairo and PDF support to
> > the build on UbuntuGIS?  This is the only reason I tried to build it
> > myself.
> > Thanks,
> > Worth
> >   _____
> > From: Alan Boudreault [mailto:aboudreault at mapgears.com]
> > Sent: Monday, March 14, 2011 1:17 PM
> > To: mapserver-dev at lists.osgeo.org
> > Cc: Worth Lutz; 'Daniel Morissette'
> > Subject: Re: [mapserver-dev] MapServer 6.0.0-beta1 release - Please test!
> > Please create a ticket, I'll verify if it's a ubuntugis bug or a
> > php/mapscript
> > one.
> > Alan
> > On March 14, 2011 11:36:49 am Worth Lutz wrote:
> > > Loaded MapServer 6.0.0 from UbuntuGIS repository.
> > > Using PHP mapscript:
> > > $ms = ms_newMapObj('mapfile');
> > > $metadata = $ms->getMetaData('coord_sys');
> > > The getMetaData statement causes a Segmentation fault.
> > > This works in 5.6.6.
> > Alan Boudreault
> > Mapgears
> > http://www.mapgears.com
> >   _____
> > No virus found in this message.
> > Checked by AVG - www.avg.com
> > Version: 10.0.1204 / Virus Database: 1498/3506 - Release Date: 03/14/11
Alan Boudreault
Mapgears
