[mapserver-dev] Axis order in WMS 1.3.0 (#3582)
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed May 4 09:05:47 EDT 2011
> I think it's to late for the 6.0 release as this issue needs more investigation. But I'm pretty sure the current behavior of MapServer is not correct.
I think the list of what is considerer "inverted" is indeed limited.
The list you provided if correct could be the solution and is available
in #3582. If you can confirm that, we can apply that list for the next
release.
best regards,
> Best regards,
> Martin
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
