[mapserver-dev] Axis order in WMS 1.3.0 (#3582)
Martin Kofahl
M.Kofahl at gmx.net
Wed May 4 09:51:12 EDT 2011
If MapServer holds the complete list of north/east codes, there's no reason a) for the update scripts and b) for the inverted flag in mapaxisorder.h.
Ticket updated, see http://trac.osgeo.org/mapserver/attachment/ticket/3582/3582.patch. I try to reach some experts regarding epsg codes and WMS. I can confirm axes order for the few codes I use, only (4326, 3146*, 239*).
Kind regards,
Martin
-------- Original-Nachricht --------
> Datum: Wed, 04 May 2011 09:05:47 -0400
> Von: Yewondwossen Assefa <yassefa at dmsolutions.ca>
> An: Martin Kofahl <M.Kofahl at gmx.net>
> CC: mapserver-dev at lists.osgeo.org
> Betreff: Re: [mapserver-dev] Axis order in WMS 1.3.0 (#3582)
> > I think it's to late for the 6.0 release as this issue needs more
> investigation. But I'm pretty sure the current behavior of MapServer is not
> correct.
> I think the list of what is considerer "inverted" is indeed limited.
> The list you provided if correct could be the solution and is available
> in #3582. If you can confirm that, we can apply that list for the next
> release.
> best regards,
> > Best regards,
> > Martin
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
