[mapserver-dev] Axis order in WMS 1.3.0 (#3582)
Martin Kofahl M.Kofahl at gmx.net
Wed May 4 11:37:02 EDT 2011
Hi -
I talked to some colleagues and they confirmed that WMS 1.3.0 strictly follows the axes ordering from the epsg definition. So the list attached to #3582 should be correct and comprehensive. However, it must be updated when there are new codes added to the epsg database. There's a subscribable announcement list at http://www.epsg-registry.org/.
I'd suggest to have a list of north/east epsg codes only. Patch is attached to #3582, too.
Kind regards,
Martin
-------- Original-Nachricht --------
> Datum: Wed, 04 May 2011 09:05:47 -0400
> Von: Yewondwossen Assefa <yassefa at dmsolutions.ca>
> An: Martin Kofahl <M.Kofahl at gmx.net>
> CC: mapserver-dev at lists.osgeo.org
> Betreff: Re: [mapserver-dev] Axis order in WMS 1.3.0 (#3582)
> > I think it's to late for the 6.0 release as this issue needs more
> investigation. But I'm pretty sure the current behavior of MapServer is not
> correct.
>   I think the list of what is considerer "inverted" is indeed limited.
> The list you provided if correct could be the solution and is available
> in #3582. If you can confirm that, we can apply that list for the  next
> release.
> best regards,
> > Best regards,
> > Martin
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
