[mapserver-dev] testing CLUSTER object
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 5 08:17:55 EDT 2011
On 11-05-05 3:32 AM, Stefanie Senn wrote:
> Hi Jeff,
> did you know something about the FeatureInfo of clustered objects?
> At the moment you get just one query result from a cluster!
> What should we do to contain the correct number of query results?
> Stefanie
Hello Stefanie,
I have included the MapServer-dev mailing list in this email (can you
make sure to follow this discussion there? thanks).
Hmm, yes I think this is related to a point I made to the mapserver-dev
list when I initially tested the cluster object (see below). I could
only ever receive one result when querying a cluster object (I assumed
all features inside the cluster object would be returned by a query).
Hopefully this generates some discussion on the mapserver-dev list.
-jeff
On 11-04-14 12:03 PM, Jeff McKenna wrote:
> - I think there is a problem with query results from a cluster. If I
> query a non-cluster-object group of features with mode=nquery (and a
> template set at the LAYER level) I get the correct number of features
> returned; If I query the same cluster-object group of features with
> mode=nquery (and a template set at the LAYER level) I only ever get one
> feature result (testing with MapServer trunk). Thoughts?
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
