[mapserver-dev] testing CLUSTER object
Tamas Szekeres
szekerest at gmail.com
Thu May 5 09:11:56 EDT 2011
2011/5/5 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hmm, yes I think this is related to a point I made to the mapserver-dev
> list when I initially tested the cluster object (see below). I could only
> ever receive one result when querying a cluster object (I assumed all
> features inside the cluster object would be returned by a query). Hopefully
> this generates some discussion on the mapserver-dev list.
Hi Jeff,
The term "all features inside the cluster object would be returned by a
query" would imply that the cluster provider should behave differently
according to the query and the drawing operations. Currently there's no
reliable mechanism to identify a purpose of a particular feature access so
this cannot be implemented in this form. We have been talking about (with
Steve) to use the query object of the map for this purpose, however it is
not handled consistently throughout MapServer (for example in drawQuery) so
it cannot be utilized here.
What I have already mentioned to workaround the problem, is to use an union
layer (with cluster setting) to provide the drawing and use the source
layer(s) to provide the query results, something like:
LAYER # non queryable, might not be exposed in WMS
NAME "cluster-layer"
CONNECTIONTYPE UNION
CONNECTION "source-layer"
STATUS default
CLUSTER
REGION "ellipse"
MAXDISTANCE 40
END
CLASS
END
END
LAYER
NAME "source-layer"
TEMPLATE "query" #queryable
CONNECTIONTYPE OGR
CONNECTION ...
STATUS default
CLASS
STATUS off # do not draw this layer but expose in legend
END
END
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110505/aa0c841a/attachment-0001.html
