[mapserver-dev] MapServer 6.0.0-rc2 release
Daniel Morissette dmorissette at mapgears.com
Thu May 5 22:37:33 EDT 2011
The MapServer Team is pleased to announce the release of MapServer
6.0.0-rc2 (we need to issue a new release candidate since a few
important issues were reported and fixed in rc1).
The 6.0 release introduces important changes in key components of the
MapServer core (rendering, query and expressions), and for this reason
we count on you, MapServer power users, to help test the release in your
respective environments and provide feedback (through the users list or
Trac tickets).
If all goes well and no blocker issues are reported, then this release
candidate could lead us to a final 6.0.0 release next week. The full
release plan which also includes the list of new features and changes in
this release is available at:
   http://mapserver.org/trunk/development/release/release-plan-6.0.html
The list of fixes since the last beta is attached at the end of this
message. For a complete list see the HISTORY.TXT file at:
http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-rc2/mapserver/HISTORY.TXT
We have started working on a 5.6 -> 6.0 migration guide. This document
contains important notes on backwards incompatibilities or other changes
required when upgrading to 6.0. The latest version is available online at:
     http://mapserver.org/trunk/MIGRATION_GUIDE.html
The source for this release can be downloaded at:
     http://mapserver.org/download.html
or
     http://download.osgeo.org/mapserver/mapserver-6.0.0-rc2.tar.gz
The binary distributions listed in the download page should be updated
with binaries for the new beta release in the next day or so.
Once again we need your help to ensure a high quality product, so please
help out by testing your applications with this new code base.
Thanks! - The MapServer Team
Version 6.0.0-rc2 (2011-05-05)
- Fixed seg fault with [shpxy] tag... (#3860)
- Removed obsolete msQueryByOperator() function
- Call msLayerClose() before msLayerOpen() in the various query
   functions (#3692)
- Fix WMS 1.3.0 to use full list of epsg codes with inverted axis (#3582)
- PHP/Mapscript: Added getResultsBounds() method in layer object (#2967)
- Fix SLD containing a PropertyIsLike filter (#3855)
- Fixed msUnionLayerNextShape to return correct values (#3859)
- Union layer: fix for the failure if one or more of the source layers
   are not in the current extent (#3858)
- Fix memory leak in msResampleGDALToMap() (#3857)
- Fix missing initialization of default formats in WCS 1.x.
- Fix maxoverlapangle when value is set to 0 (#3856)
