[mapserver-dev] CONNECTIONTYPE UNION with STYLEITEM AUTO still
not working in 6.0.0-rc2 (and possible solution)
Tamas Szekeres
szekerest at gmail.com
Tue May 10 05:39:20 EDT 2011
Jana,
I've just tested the SYMBOL binding with STYLEITEM AUTO and works for me. I
expect that the [icon] parameter should contain the name of a valid symbol
definition, isn't it? Could you wrap up a small example (mapfile+data) to be
able to reproduce your test case?
Best regards,
Tamas
2011/5/10 Jana Golinowski <jgolinowski at codematix.de>
> Could you provide the mapfile which doesn't work for you?
> The source layers are styled with values from database (icon, heading,
> length). They are displaying correctly. Looking into MS_ERRORFILE I can see
> MapServer requesting the items for styling and labeling. But the union layer
> appears to be empty because those items are not requested.
> After changing 'SYMBOL [icon]' to 'SYMBOL
> "symbol/ais/ship_no_heading_black_3.png"' (for example in layer
> "ais_notmoving_noheading") the union layer isn't "empty" anymore. But that's
> not what I need here.
> I just tested this with the current trunk (rev 11665) with the same result.
> But as I said before I may have misunderstood something.
> Greetings, Jana.
> MS_ERRORFILE extract when displaying a source layer:
> msPostGISBuildSQLItems: 2 items requested.
> msPostGISLayerNextShape called.
> msPostGISReadShape called.
> msPostGISReadShape: PQgetlength = 38
> msPostGISReadShape: [icon] "symbol/ais/ship_no_heading_black_3.png"
> msPostGISReadShape: PQgetlength = 9
> msPostGISReadShape: [feature_of_interest_id] "211215680"
> msPostGISReadShape: Setting shape->index = 3433260
> msPostGISReadShape: Setting shape->resultindex = 1
> msPostGISReadShape: [index] 3433260
> msPostGISReadShape: [shape] POINT (8.9474133333333334 52.3004283333333362)
> msPostGISBuildSQLItems: 0 items requested.
> The extract from the mapfile:
> LAYER
> NAME "ais_notmoving_union"
> STATUS ON
> CLASS
> END
> # hidden block DATASOURCE
> TYPE POINT
> CONNECTION "ais_notmoving_noheading,ais_notmoving_shape"
> # end hidden block
> TOLERANCE 0
> DEBUG 5
> GROUP "AIS_union"
> PROJECTION
> "init=epsg:4326"
> END
> PROCESSING
> "ITEMS=feature_of_interest_id,feature_of_interest_name,outline,icon,length,heading,sog,cog"
> STYLEITEM "AUTO"
> END
> LAYER
> NAME "ais_notmoving_noheading"
> STATUS OFF
> CLASS
> STYLE
> SYMBOL [icon]
> SIZE 20
> END
> LABEL
> SIZE SMALL
> TYPE BITMAP
> COLOR 0 0 0
> END
> TEXT "Test: not moving, no heading [feature_of_interest_id]"
> END
> DATA "geom from ais_sos.wfs_view"
> TYPE POINT
> CONNECTION "dbname=jweb_ais_dev user=postgres host=localhost port=5432"
> CONNECTIONTYPE POSTGIS
> # end hidden block
> PROJECTION
> "init=epsg:4326"
> END
> FILTER "(geom_velocity is null or sog is null or sog <= 0) and
> astext(geom) != 'GEOMETRYCOLLECTION EMPTY' and heading is null"
> DEBUG 5
> GROUP "AIS_union_source_notmoving"
> END
> LAYER
> NAME "ais_notmoving_shape"
> STATUS OFF
> CLASS
> STYLE
> SYMBOL [icon]
> SIZE [length]
> ANGLE [heading]
> END
> LABEL
> SIZE SMALL
> TYPE BITMAP
> COLOR 0 0 0
> END
> TEXT "Test: not moving, shape [feature_of_interest_id]"
> END
> TYPE POINT
> # end hidden block
> DEBUG 5
> astext(geom) != 'GEOMETRYCOLLECTION EMPTY' and heading is not null and
> length is not null and length > 0"
> PROJECTION
> "init=epsg:4326"
> END
> SYMBOLSCALEDENOM 3000
> END
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110510/a814b92b/attachment.html
