[mapserver-dev] CONNECTIONTYPE UNION with STYLEITEM AUTO still
not working in 6.0.0-rc2 (and possible solution)
Jana Golinowski
jgolinowski at codematix.de
Tue May 10 09:31:54 EDT 2011
> I've just tested the SYMBOL binding with STYLEITEM AUTO and works for
> me. I expect that the [icon] parameter should contain the name of a
> valid symbol definition, isn't it? Could you wrap up a small example
> (mapfile+data) to be able to reproduce your test case?
[icon] contains the path to a png file (relative to the mapfile) which is
working when the source layer itself is drawn. I also tried to use a simple
circle (ellipse) as symbol and take the color for it from database. But the
result is the same.
I attached a simplified example with about 20 points. The three source layers
are drawn correctly, the union layer is an empty picture. You can also test it
with 'SYMBOL [icon]' in the source layers.
Greetings, Jana.
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110510/430a01e0/union_item_test-0001.bin
