[mapserver-dev] CONNECTIONTYPE UNION with STYLEITEM AUTO still
not working in 6.0.0-rc2 (and possible solution)
Jana Golinowski
jgolinowski at codematix.de
Wed May 11 06:08:32 EDT 2011
> [icon] contains the path to a png file (relative to the mapfile) which
> is working when the source layer itself is drawn. I also tried to use a
> simple circle (ellipse) as symbol and take the color for it from
> database. But the result is the same.
> I attached a simplified example with about 20 points. The three source
> layers are drawn correctly, the union layer is an empty picture. You can
> also test it with 'SYMBOL [icon]' in the source layers.
I just tested my mapfile with the current trunk (rev 11669). All seems to be
fine now.
Thanks.
Greetings, Jana.
