[mapserver-dev] MapServer PostGIS Layer with And and
PropertyIsGreaterThanOrEqualTo (multiple rules) not working
Debasish Sahu
debasish.sahu at gmail.com
Mon May 16 11:31:57 EDT 2011
I have a Postgis layer and trying to create a thematic map using SLD. The
field on which the thematic is created is Integer.
When the SLD is applied the whole layer gets rendered using the symbolizer
defined in the first rule.
If I try the same SLD using ESRI Shapefile layer it works fine . Any ideas
Thanks and Warm Regards
Debasish Sahu
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110516/51f1df5e/attachment.html
