[mapserver-dev] Possible BUG: MapServer WMS SLD with
ExternalGraphic not working using trunk codebase
Debasish Sahu
debasish.sahu at gmail.com
Mon May 23 12:02:54 EDT 2011
When I try to render a Polygon shapefile with a SLD file using the
ExternalGraphic , the mapserver crashes. After investigating the cause by
putting the DEBUG in map file and
analyzing the temporary map file that is created , it seems the SYMBOL ,
TYPE Pixmap tags are not getting created . Only the Symbol tag in the Layer
is present.
The image file gets downloaded into the temp dir.
Can someone please confirm it is a bug with the current trunk codebase ?
LAYER
DATA "states"
METADATA
"wms_srs" "EPSG:4326"
"wms_title" "states"
END # METADATA
NAME "states"
PROJECTION
"init=epsg:4326"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
NAME "states"
STYLE
ANGLE 0
COLOR 255 0 0
OFFSET 0 0
SIZE 10
SYMBOL "http://demo.mapserver.org/ogc-demos/etc/images/target-1.gif"
END # STYLE
STYLE
ANGLE 0
OFFSET 0 0
OUTLINECOLOR 0 0 0
END # STYLE
END # CLASS
END # LAYER
Thanks and Warm Regards
Debasish Sahu
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110523/d5fd7c10/attachment.html
