[mapserver-dev] Possible BUG: MapServer WMS SLD with
ExternalGraphic not working using trunk codebase
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue May 24 10:19:44 EDT 2011
SYMBOL "http://demo.mapserver.org/ogc-demos/etc/images/target-1.gif"
should be valid and the would in effect download your symbol and use it
for the fill.
Here is a simple SLD I am using to do local tests and does seem to give
expected result, Can you also try it?
<StyledLayerDescriptor
version="1.0.0"><NamedLayer><Name>province</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><PolygonSymbolizer><Geometry><PropertyName>the_area</PropertyName></Geometry><Fill><CssParameter
name="fill">#ff0000</CssParameter><GraphicFill><Graphic><ExternalGraphic><OnlineResource
xlink:type="simple"
xlink:href="http://demo.mapserver.org/ogc-demos/etc/images/target-1.gif"/><Format>GIF</Format></ExternalGraphic><Size>10.0</Size></Graphic></GraphicFill></Fill></PolygonSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>
Looking at the map file generated, I see a second style that seems to
indicate a "stroke" element was given in the SLD to create an outline on
the polygon. I tried to do the same and that gave me an issue where the
2nd style "hiding" the first style with what seems to be a white fill. I
have raised this issue in http://trac.osgeo.org/mapserver/ticket/3891
and when fixed the map file given in your example should draw expected
results.
best regards,
On 23/05/2011 12:02 PM, Debasish Sahu wrote:
> Hi,
> When I try to render a Polygon shapefile with a SLD file using the
> ExternalGraphic , the mapserver crashes. After investigating the cause
> by putting the DEBUG in map file and
> analyzing the temporary map file that is created , it seems the SYMBOL
> , TYPE Pixmap tags are not getting created . Only the Symbol tag in
> the Layer is present.
> The image file gets downloaded into the temp dir.
> Can someone please confirm it is a bug with the current trunk codebase ?
> LAYER
> DATA "states"
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_title" "states"
> END # METADATA
> NAME "states"
> PROJECTION
> "init=epsg:4326"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "states"
> STYLE
> ANGLE 0
> COLOR 255 0 0
> OFFSET 0 0
> SIZE 10
> SYMBOL
> END # STYLE
> STYLE
> ANGLE 0
> OFFSET 0 0
> OUTLINECOLOR 0 0 0
> END # STYLE
> END # CLASS
> END # LAYER
> Thanks and Warm Regards
> Debasish Sahu
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110524/bf61d725/attachment.html
