[mapserver-dev] map is not displayed using ms4w and postgis
sanjib chatterjee
sanjibchatterjeegis at gmail.com
Tue May 24 07:44:12 EDT 2011
Hi All,
I am using geomoose2 framework + ms4w + postgresql 9.0 and postgis 1.5.
While my mapscript use DATA from shape file and / or from mysql table ,map
is generated and displayed well.
but when it fetch from postgresql it fails to generate map. I am not getting
any error message.
Please help to find my problem.I am new in this area. I gave bellow my
mapscript for shape,mysql and postgis.
read from shape:-
MAP
NAME "Internal_plots"
STATUS ON
TRANSPARENT ON
INCLUDE "../../../geomoose_globals.map"
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 8
COLOR 0 0 0
END
END
LAYER
NAME Internal_plots
STATUS ON
TYPE POLYGON
LABELITEM 'DAG_NO'
TRANSPARENCY 100
LABELCACHE ON
CLASSITEM 'DAG_NO'
DATA './Internal_plots'
CLASS
NAME 'dag_no'
STYLE
SYMBOL 'plainline'
SIZE 1
COLOR 255 255 255
OUTLINECOLOR 0 0 0
END
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 10
ANTIALIAS TRUE
COLOR -1 -1 -1
OUTLINECOLOR -1 -1 -1
BUFFER 4
MINFEATURESIZE auto
PARTIALS FALSE
POSITION cc
END
END
METADATA
'identify_record'
'../../Common/Template/village/identify_village.html'
'peak_record'
'../../Common/Template/village/village_peak.html'
'select_record'
'../../Common/Template/village/select_village.html'
'select_header'
'../../Common/Template/village/select_header_village.html'
'popups'
'../../Common/Template/village/village_popup.html'
'itemquery'
'../../Common/Template/village/village_itemquery.html'
# 'itemquery-filteritem' 'OWNER_NAME'
'itemquery-filter' '/.*[qstring].*/i'
'qstring_validation_pattern' '.'
# Feature reports are stored in the conf/feature_report
directory.
'feature_report' 'village.shp.xml'
END
TOLERANCE 0
END
END ## end Map
### report: work well
Read from mysql , only DATA section,rest all are same
CONNECTIONTYPE OGR
CONNECTION "MySQL:bmaapp,user=root,password=root,port=3306"
DATA "SELECT * from internal_plots ;"
Read from postGIS only DATA section,rest all are same
CONNECTIONTYPE postgis
CONNECTION 'host=localhost port=5432 dbname=postgis user=postgres
password=root at 2011'
DATA 'the_geom from Internal_plots'
### report: map is not displayed
please note that from pgadmin III sql query if we give select the_geom
from public."Internal_plots" then gives the geomtry column as output but
only select the_geom from Internal_plots OR the_geom from
Internal_plots does not give output rather second one is syntax error and
first one is giving message that Internal_plots relation does not exist.
With Thanks and best regards
Sanjib Chatterjee
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110524/1a591032/attachment.html
