[mapserver-dev] ticket 3153 fixed in MapServer 6.0?
Brent Fraser
bfraser at geoanalytic.com
Tue May 24 17:36:47 EDT 2011
FYI, a possibly related ticket: http://trac.osgeo.org/mapserver/ticket/875
Best Regards,
Brent Fraser
On 5/24/2011 3:30 PM, Worth Lutz wrote:
> Is this ticket http://trac.osgeo.org/mapserver/ticket/3153 fixed in
> MapServer 6. I am using version 6.
> I've spent some time today tracking down a problem with changing my
> resolution of my map from 72 to 300.
> I scaled up the width and height and changed the resolution.
> Defresolution was left at the default.
> I displayed the two maps on the screen with the same height and
> width. The two maps should have looked the same but the labels were
> tiny on the map with a resolution of 300.
> After much google searching, testing and head scratching, I finally
> figured out that it was a "MAXSCALE"value in the layer in the
> mapfile. The "SIZE" was set to 7 and the "MAXSCALE"set to 7.
> Removing the "MAXSCALE"value fixed this layer. There was no
> SYMBOLSCALEDENOMin this layer. Thus this was not a good test.
> Now looking at another I am seeing a problem with another layer.
> Layer definition below.
> The labels on the State Roads are good with resolution at 72 and tiny
> with resolution set to 300.
> If I remove the three lines, SYMBOLSCALEDENOM, MAXSIZE, MINSIZE, I
> get identical maps at both resolutions.
> Am I doing something wrong or is this a bug I should report?
> Worth Lutz
> LAYER
> NAME "highways_anno"
> GROUP "NCDOT_trans_grp"
> STATUS off
> TYPE ANNOTATION
> DATA "/data/NCDOT/shapefiles/LRS_Arcs"
> MAXSCALEDENOM 3750001
> TEMPLATE void
> CLASSITEM "rte_1_clss"
> LABELITEM "rte_1_nbr"
> SYMBOLSCALEDENOM 1000
> CLASS
> EXPRESSION "SR" # State Roads
> MAXSCALEDENOM 25001
> COLOR 0 0 0 # dummy color
> TEXT "(SR[rte_1_nbr])"
> LABEL
> BUFFER 15
> TYPE TRUETYPE
> MINFEATURESIZE 5
> MINDISTANCE 150
> POSITION auto
> ALIGN center
> ANGLE follow
> FONT vera
> ANTIALIAS true
> SIZE 11
> MAXSIZE 11
> MINSIZE 6
> COLOR 0 0 255
> END
> END
> END
> Worth Lutz
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110524/8636679e/attachment.html
